Φυλερ κυριοι !!!!!!!
Διακενο εισαγωγης:0,10
Διακενο εξαγωγης: 0,13
  • Απαντήσεις 256
  • Εμφανίσεις 25,9k
τωρα θα χαθει η μπαλα ......και με απαντησεις απο χιτσκοκ ,αναφερονται στα ταπετα που παιρνουν κινηση απο τα εκκεντρα!!!
I enquired about the "Performance Cam" data and "Fast Road or Road
Racing Cam" data from Hitchcocks Motorcycles, and I'm posting the
info that I got, so that everyone can share.
This info is not anywhere on the web(that I could find), so perhaps
some of you were wondering about it too.
*******************Performance Cams***********************
CAMSHAFTS  Part 200180  (Feb 2004)
The following is the approximate timing for the above camshafts set
with 0.012" tappet checking clearance:
NB THIS TAPPET CLEARANCE IS USED FOR CHECKING CAM TIMING ONLY. FOR
NORMAL RUNNING THE INLET AND EXHAUST TAPPET CLEARANCE SHOULD BE SET
TO 0.002" FOR THE INLET AND 0.002" FOR THE EXHAUST.
Inlet opens 50o BTDC   Exhaust opens  65o BBDC
Inlet closes 60o ABDC   Exhaust closes 45o ATDC
Inlet cam lift 0.380"
        Exhaust lift 0.365"
These cams will enhance the performance with the standard Indian
made silencer and carburetter, but for optimum performance a freer
flowing system is highly recommended. You will also benefit from a
slightly higher gearing. We suggest 17 teeth (part number H49/17)
for the 350cc and 18 teeth (part number H49/18) for the 500cc.
Things to check
Please check the following clearances:
It will be necessary to machine the crankcase to allow full rotation
of the exhaust camshaft. This can be done using a small grindstone
on an electric drill with the engine in place. Care must be taken to
ensure that only the minimum of alloy is removed to avoid weakening
the main bearing housing. This job will be made easier with the
timing pinion removed. Be certain that all debris is removed and the
crankcases thoroughly cleaned. Also check that there is clearance
for the inlet cam to rotate. Our recommendation is at least 0.020"
for each between the top of the lobe and crankcase.
Clearance between the piston and Inlet valve minimum of  0.060"
and for the exhaust valve a minimum of  0.100"
Clearance between the Inlet valve guide and top collar minimum of
0.060" and for the exhaust a minimum of  0.100"
Make sure that the valve springs are unlikely to get coil bound. We
suggest using our special competition valve spring set, part number
VS420A.
Due to the tolerances in crankcase machining please check the
clearance between the cam follower head and the cam gear wheel. Use
the enclosed shim(s) to place on the cam spindle before fitting the
cam to give a clearance of at least 0.005".
As with the original equipment cams, it is not necessary but
preferred that the end float between the cam and timing cover is
adjusted to 0.005" -  0.010". This is done with the standard shim(s)
(part number 112078) This will help prevent excessive gear train
noise. Later timing cover gaskets are thicker than the earlier
gaskets, although a better gasket will require more shimming.
Please ensure that the cam spindles and cam followers are in good
condition as any wear in these components will transfer to the new
cams reducing their life span.
To ensure maximum performance gain from these cams the rest of the
engine needs to be in good working order. E.G. valves seating
correctly, no excessive wear in cylinder bore and piston and correct
setting of carburation and ignition timing.
Set the tappet clearance to Zero on both cams when the piston is at
TDC on the compression stroke. (Please note that this will give the
required increased clearance when the cam is at its lowest point).
*******************Fast Road or Road Racing Cams*******************
CAM SHAFTS Part 90023
The following is the timing for the above camshafts set with 0.040"
(Please do not compare to workshop manual settings as these are set
to 0.012" tappet checking clearance)
RUNNING CLEARANCE WE RECOMMEND 0.001" FOR THE INLET AND 0.003" FOR
THE EXHAUST. (MEASURED WITH PISTON AT TOP DEAD CENTRE ON COMPRESSION
STROKE).
Inlet opens 48o BTDC   (33o) Exhaust opens  78o
BBDC     (60o)
Inlet closes 78o ABDC  (42o) Exhaust closes 48o
ATDC     (14o)
The figures in brackets are a set of standard Indian cams measured
with the same 0.040" tappet clearance
Inlet cam lift 0.425"
        Exhaust lift 0.420"
Things to check
for the inlet cam to rotate as the crankcases can vary. Our
recommendation is at least 0.020" for each between the top of the
lobe and crankcase.
Clearance between the piston and Inlet valve minimum of 0.080" and
VS420A.
(part number 112078). This will help prevent excessive gear train
gaskets and although a better gasket these will require more
shimming.
condition, as any wear in these components will transfer to the new
****************Allan Hitchcock's Comments************************
Please find attached the fitting instructions for our cams. The peak
performance with standard timing is between 5400 and 5500 revs, and
both will run comfortably upto 6500, but 6000 is the owners normal
redline. 200180 will be an improvement over the standard cams from
about 3000 revs. 90023 from about 400 revs higher.
To be honest, I run the 90023 cams in my bike and I use it round
town with a reversed cone megaphone and it is easy to ride and ticks
over well. I run at about 30 degrees advance (standard is 32).
I think the 34mm carb will be too big, you will probably lose out a
bit on a clean lower end and tick over. I would favour the 32mm.
Regards, Allan
Hope you find it useful.
Ace
απο το επισημο Αγγλικο φορουμ της ενφιλντ ....
henry
Rally Meister
  icon_minipost.gifPosted: Sat Jun 16, 2012 8:51 am    Post subject: icon_quote.gif Bit of info for you keen cam fans.
Indian Bullets valve timing is (with 0.012 clearance)
Exhaust opens 75 BDC
Exhaust close 35 after TDC
Inlet opens 30 BTDC
Inlet closes 60 after BDC
Valve lift 0.3125 inch
Redditch bullet 500cc fitted to all late 500cc till last build (with 0.012 clearance)
Exhaust close 35 ATDC
Inlet opens 30 BTDC
My cams which I supply (with 0.012 clearance)
Exhaust opens 83 BDC
Exhaust closes 35 after TDC
Inlet opens 24 BTDC
Inlet closes 73after BDC
Valve lift Exhaust 0.328 in
Valve lift Inlet 0.344 ins
I do not have the cam timing details for electra X
Henry
_________________
Those who don't take orders, Take command
trbe5t..jpg The British Bulleteers Forum
SPONSORED BY PRICE PARTS MOTORCYCLES - 01454 261798 www.pricepartmotorcycles.co.uk
αρα αν το valve lift ειναι αυτο που θελουμε και το δινει στα 0.3" μας βγαζει 0.8 εκατοστου ,
αλλα το valve lift δεν ειναι αυτο που θελουμε ! η ειναι ? η δεν ειναι?
και το clearance 0.012 τι ειναι ?
ειναι το διακενο της βαλβιδας? η δεν ειναι?η ειναι?
ειναι των βαλβιδων? ειναι των ταππετων εκκεντροφορου?
σας μπερδεψα?
ουτε το 0.012 ιντσας ειναι ουτε το 0.10 εκατ. ειναι?
οριστε τι λενε στου χιτσκοκ τη σελιδα για τη ρυθμιση ταππετων
Page  1
Tappet clearence
Started at 02:49pm on the 6th March, 2008 by John John Subject: Tappet clearence What are the tappet clearences on a 2002 classic 500 indian bullet, are they set hot or cold. Posted: 02:49pm 6th March, 2008 Peter B (350 1991 bullet FR) Subject: Re: Tappet clearence The manual says zero clearance when cold. This is achieved when the push rod ends just turn under finger pressure. I have found that all is quiet just after starting, when cold but rather clanky when hot. According to http://www.cybersteering.com/cruise/feature/bullet/adj_pushrod.html
B. R. Gurunandan says do it hot. It is a lot quieter but I took the precaution of checking the compression after the engine had cooled down again.
I expect I shall get a lot of comments!
Peter Posted: 03:02pm 6th March, 2008 CJay Subject: Re: Tappet clearence Generally most bullet�s tappet clearance increases when the engine gets warm. Different combinations of barrels, push rods and cams effect the amount of growth. Alloy barrels with steel rods are the worst I�ve found. In talking to our host on the subject some time ago they have occasionally found an exception to this rule so always be careful.
So the idea is to get the clearance as tight as you can cold and still have enough compression to get it started. When the engine warms up you will have the correct clearance.
Setting the clearance hot can cause problems. I�ve had the experience of setting the clearance to .001 to .002 hot and then, after the engine cooled down I did not have enough compression to get it started. This was with an alloy barrel and steel push rods.
What I recommend to people is to set them cold using the following procedure:
- Back off both adjusters to insure full valve closure.
- Bring the piston up on a compression stroke with the kick starter and then stand up on the kick start lever. This give you a yard stick of what the full compression of your engine feels like by how long it will hold your weight.
- start with the intake (or exhaust, doesn�t matter) and tighten it up to zero. Now give it a 1/16th turn tighter and stand up on the kick starter. If you still have any compression then give it another 1/16th turn and stand up on the kick starter. Repeat this procedure until you no longer have any compression then back off the adjust 1/16th turn. This should put you back to the last setting that still had any compression. Stand on the kick starter and verify this then lock the adjuster.
- Repeat the above step with the other valve.
- Start the engine and let it warm up (hot to the touch on the rocker covers).
- Stop the engine and either stand up on the kick starter on a compression stroke and compare that to your yard stick above OR remove the tappet cover and, on a compression stroke, make sure you can freely spin the push rods.
This method will give you very quite valves (or as quite as they will ever get without burning them).
CJay Posted: 04:13pm 6th March, 2008
ποιος τροπος θα σου αποφερει τις πιο αθορυβες βαλβιδες κατα την λειτουργια? οριστε ,το λεει και απο πανω !
Αρα τελικα το λεγομενο nil μηδενικο ειναι 0.06mm στο κοκορακι.
https://imagizer.imageshack.us/v2/320xq90/r/538/nk9ptt.png
Απλως εγω δεν μπορω να πιστεψω πως τα ελατηρια της Enfield
κατα την ωρα των 90χλμ/ωρα προλαβαινουν να επιστρεφουν 20 φορες/δευτερολεπτο
τη βαλβιδα στην εδρα της.
. . για αυτο κ ρυθμιζω 0.10 κ 0.13 εξαγωγη
. .και παλι στα 0.13 δεν χτυπουν τα κομορακια μου.
. ." ειμαι ο τρελος του χωριου . . . αλλα την εξαγωγη μου ΔΕ τη ρυθμιζω
με τιποτα 0.06mm
...Χρήστο πάλι ποτ@ν@ το κάναμε...!!!
...οι αγαπητοι διαχειρηστε παρακαλουντω όπως μεταφέρουν τα ποστ των βαλβίδων στο ανάλογο θεμα...!!!
...εγω πάντως Χρήστο ακόμα δεν καταλαβα τι ειναι ο κάθε όρος στα αγγλικα...!!!
...αν μπορεις κάνε μία μεταφραση valve lift και οι άλλοι αγγλικοι όροι που συμπήπτουν και τί είναι ο κάθένας ή σε ομάδα...!!!
...απλα και οχι με πολλα πολλα σαν να μηλας σε βλαμένο, εμένα δηλαδηςςςς...όπαλάκιαααααα...!!!
στεφανε παλι μπερδευτηκες !!!
το ταππετ που λεει εννοει τα ταπετα των εκκεντρων ( αυτα που εβαλα φωτο και μοιαζουν με βαλβιδες), δεν λεει για τα κοκορακια πιστευω....
Χρηστο απο αγγλικη μηχανολογια τα παω αρκετα καλα.
Πιστεψε με , δεν μπερδευτικα .
Χαρηκα που επιτελους αποφανθηκαν για το tapped clearance και το ορισαν στο0.06mm
Χρηστο αυτο το ζητημα με τα διακενα , εχει πολυ ενεργεια.
Θα το συζητησουμε απο κοντα , με την ησυχια μας.
Το tapped clearance ειναι η ελευθερία μεταξύ του εκκεντρου γραναζιου και του ταπετου ( tappet clearance)( ταπετο ειναι αυτό που μοιάζει με βαλβίδα και στο οποίο εδράζει το ωστηριο) και του δίνουν τιμή 0.001"
Άρα έχουμε τελικά ,
Διάκενο μεταξύ πιανολας( rocker arm) και βαλβίδας 0.012" valve clearance
Διάκενο μεταξύ αμυγδάλου του εκκεντρου γραναζιου και ταπετου 0.001" tappet clearance
Σήκωμα βαλβίδας 0.31" valve lift
Βαλβίδα εξαγωγής ανοίγει 75 μοίρες κατω νεκρού σημείου ( below dead center BDC)
και κλείνει 35 μοίρες μετα άνω νεκρό σημείο ( after top dead center , after TDC)
Βαλβίδα εισαγωγής ανοίγει 30 μοίρες προ άνω νεκρού σημείου ( before top dead center BTDC)
και κλείνει 60 μοίρες μετα κατω νεκρού σημειου( after below dead center ,after BDC)
Τα παντα ολα ,
.- Δηλ. Τελεία και παύλα!!!
Εδώ τι λέει όμως ο χιτσκοκ?
Βελτιωμένοι εκκεντροφόροι
Εκκεντροφόροι με κωδικο 200180
Τα ακόλουθα αφορούν στον χρονισμό ανωτέρω εκκεντροφόρων οι οποίοι σεταριστικαν με 0.012" διάκενο ταπετων,
Προσοχή αυτό το διάκενο χρησιμοποιήθηκε μονο για τον έλεγχο του χρονισμού του εκκεντροφόρου.
Για νορμάλ ταχύτητες οδήγησης τα ταπετα εισαγωγής και εξαγωγής να ρυθμιστούν στα 0.002" για εισαγωγή και 0.002 " για εξαγωγή.
Εισαγωγής βαλβίδα ανοίγει ...... Και παει λέγοντας.....
Χρηστο δυο διαφορετικες σελιδες απο το ΙΔΙΟ βιβλιο αναφερουν
https://imagizer.imageshack.us/v2/320xq90/r/913/E5flC3.png
https://imagizer.imageshack.us/v2/320xq90/r/661/Dykkbb.png
. .το βιβλιο ειναι απο το servive manual της Enfield Super Meteor.
Y.Γ . .. αραγε γιατι σε νορμαλ συνθηκες το διακενο να ναι μηδενικο
αλλα σε ΥΨΗΛΕΣ ΤΑΧΥΤΗΤΕΣ να ναι 0.13 mm ?
Στεφανε τι σχέση έχει η απλη Bullet με την Super Meteor...!!!
...θα μας τρελάνεις έδω ή μας τιλήξεις για το σπίτι....εεεεεε...???
...μην συγκρήνεις διαφορετικα μηχανακια...
...ακόμα και αν έχουν ίδιες τιμες είναι λαθος αυτο...
Να ξερες ποσο λαθος εχεις Νικο.
Ευτυχως που τα "λαθος " μου αρθρα μπορει να διαβαστουν στο μελλον κ απο αλλους
ανθρωπους.
Για την ωρα εχω το δικαιωμα να διατυπωσω
και συ να αρνηθεις.
Στεφανε δεν μαθαινουμε ετσι ...ειμαι ασχετος.... και για να αντιπαρατεθεις στελνεις στοιχεια απο αλλο μοντελο...οπααα
Παρόλο που ειναι λαθος να παίρνεις τιμές απο άλλο μοντέλο ,
Σου απαντώ σύμφωνα με αυτά που σου εχω πει για τα Μπουλετ...
Το διάκενο μεγαλώνει οταν ζεστενεται ο κινητήρας ,
Θυμάσαι τι έλεγε ο μαστρο ranjeed στο βίντεο , if you adjust them loose they will become more loose,άρα adjust them tight because they will become less tight!!!
Και τι λέει ο ποιητής? Continuous ... Συνεχόμενο high speed running άρα υψηλότερες θερμοκρασίες ,που τα θες πιο χαλαρά τα πράγματα!
Δεν έχεις ακούσει επίσης που λένε το καλοκαίρι ρύθμισε τις βαλβίδες πιο χαλαρές ?
Όσο για το λαθος της σύγκρισης που το στηρίζω?
Είχα βρει σε πολλα φόρουμ που λέγανε ξεκάθαρα πως ρυθμίζουν τις βαλβίδες κάποιον συγκεκριμένων μοντέλων του 40 της Norton και της Vincent στα 0.012" ,
Θα ηταν σωςτο να το παραθέσω ως απόδειξη οτι και τα ενφιλντ δουλεύουν στο ίδιο?
Οχι!
Έψαχνα παντού να βρω αποκλειστικά Μπουλετ και μάλιστα απο 1990 έως 2004 ,και βρήκα ,και λέγανε και αυτοί 0.012",
Απλά εχω φάει κόλλημα με το 0.012 αν σχετίζεται μονο για τα ταπετα και οχι για τις βαλβίδες.....
Έχασα την μπάλα......
Στέφανε παρατήρησε ,
Αυτά που έβαλες μέσα στο κόκκινο κουτάκι ειναι οι μετρήσεις των valve tappets δηλαδή των ταπετων εκκεντροφόρων ,
Πάνω απο το κόκκινο κουτάκι ειναι άλλες 4 ακομη μετρηςεις ταπετων με τους οδηγούς τους tappet guides και πιο πάνω ειναι οι τιμές των βαλβίδων ,
Ειναι και μετεορ , και έδωσες αντί για βαλβίδες τα ταπετα .....
Ναι Χρηστο ενδεχομενως να αυξανει ελαφρως το διακενο
αλλα ΚΥΡΙΩΣ ΑΥΞΑΝΕΤΑΙ Η ΑΔΥΝΑΜΙΑ ΤΩΝ ΕΛΑΤΗΡΙΩΝ ΤΗΣ ΒΑΛΒΙΔΑΣ ΝΑ Π Ρ Ο Λ Α Β Ο Υ Ν
ΝΑ ΕΠΙΣΤΡΕΨΟΥΝ
ΤΗΝ ΒΑΛΒΙΔΑ ΣΤΗΝ ΦΩΛΙΑ ΤΗΣ ΤΗΝ ΩΡΑ ΤΟΥ ΜΠΑΜ ΤΗΣ ΣΠΙΘΑΣ
και επειδη ο αγγλος φοβαται για την αξιοπιστια των ελατηριων
αυξανει το σχεδον μηδενικο σε 0.13mm . . για να εχει το κεφαλι του ησυχο.
Ενας Enfieldas οταν παταει 95χλμ/ωρα , το ελατηριο . . . ΑΝΟΙΓΟΚΛΕΙΝΕΙ ΤΗ ΒΑΛΒΙΔΑ 15 ΦΟΡΕΣ ΤΟ ΔΕΥΤΕΡΟΛΕΠΤΟ !!!!!
