Carb Funnel From A Lamp
[center][b]Make a carb funnel from an old lamp..so simple and easy![/b][/center]
[center][url="http://1.bp.blogspot.com/-PoFDETyKn9A/ULzPPNdcAuI/AAAAAAAABdA/NWFv_jE9txc/s1600/homo+ratus+carb+funnel.JPG"][img]http://1.bp.blogspot.com/-PoFDETyKn9A/ULzPPNdcAuI/AAAAAAAABdA/NWFv_jE9txc/s320/homo+ratus+carb+funnel.JPG[/img][/url][/center]
[b] At first you must be sure that the diameter of the lamp is a little longer from your Carb.[/b]
1. Take the lamp and cut it in three pieces(look at the photo)
2. You will use the middle piece
3. Find or make a gasket to use between the funnel and the carb
4. Take a sieve and cut it 2mm shorter from the external diameter of your funnel (i used a sieve from an old car speaker)
5. Glue it with silicone (i will find a better way soon)
[url="http://1.bp.blogspot.com/-2tVhr3JDYKQ/ULzNRe-9E_I/AAAAAAAABcQ/BL0UcrNkvgI/s1600/SDC11827+efe.jpg"][img]http://1.bp.blogspot.com/-2tVhr3JDYKQ/ULzNRe-9E_I/AAAAAAAABcQ/BL0UcrNkvgI/s320/SDC11827+efe.jpg[/img][/url][url="http://2.bp.blogspot.com/-U3hMsNIQqAs/ULzNUVMnBtI/AAAAAAAABcg/8PRj8huf744/s1600/SDC11834+efe.jpg"][img]http://2.bp.blogspot.com/-U3hMsNIQqAs/ULzNUVMnBtI/AAAAAAAABcg/8PRj8huf744/s320/SDC11834+efe.jpg[/img][/url]
[url="http://4.bp.blogspot.com/-1yWWG_0TwUE/ULzNSrldD2I/AAAAAAAABcY/pXNTWYdwpCo/s1600/SDC11831+efe.jpg"][img]http://4.bp.blogspot.com/-1yWWG_0TwUE/ULzNSrldD2I/AAAAAAAABcY/pXNTWYdwpCo/s320/SDC11831+efe.jpg[/img][/url][url="http://3.bp.blogspot.com/-_LozaMX2qbw/ULzNWEXeEuI/AAAAAAAABco/8dbARn-Z-qE/s1600/SDC11836+efe.jpg"][img]http://3.bp.blogspot.com/-_LozaMX2qbw/ULzNWEXeEuI/AAAAAAAABco/8dbARn-Z-qE/s320/SDC11836+efe.jpg[/img][/url]
[center][url="http://3.bp.blogspot.com/-Fhieg38Uvrc/ULzNZfe6bII/AAAAAAAABc4/NDRms43gCxk/s1600/SDC11852+efe.jpg"][img]http://3.bp.blogspot.com/-Fhieg38Uvrc/ULzNZfe6bII/AAAAAAAABc4/NDRms43gCxk/s320/SDC11852+efe.jpg[/img] [/url][url="http://4.bp.blogspot.com/-UZPuIMN0YNA/ULzNXhgaWNI/AAAAAAAABcw/a6Buh6-L8BE/s1600/SDC11838+efe.jpg"][img]http://4.bp.blogspot.com/-UZPuIMN0YNA/ULzNXhgaWNI/AAAAAAAABcw/a6Buh6-L8BE/s320/SDC11838+efe.jpg[/img][/url][/center]
[quote name='bbk' timestamp='1354778460' post='9872']
Σε βγάζω για μία ακόμα φορα το καπέλο....έγραψες!!!!
Μην του δίνεις ιδέες, είναι ικανός να φτιάξει το φιλτροκούτι από καπέλο.. :sign0020:
[u][b]Translation:[/b][/u]
I doff a hat again....., you wrote (You did very well).
Do not give him ideas, he is able to make the airbox from a hat ..
