Δημοσιεύτηκε Απρίλιος 17, 201313 χρόνια comment_11924 Dear Enfielders after the winter stop, I have recharged the battery, popped her back in, turned the key and.... zzzzzzzzzzzzzzzzzzzz there's this electric buzzing sound that doesn't stop and the bike wont start. It's similar to the sound as when you turn on the bike but it normally lasts a a couple seconds. Is something wrong? Or does the electric starter need to be "charged" after the winter and I should let it buzz for a while?? thanks Αναφορά
Δημοσιεύτηκε Απρίλιος 17, 201313 χρόνια Συγγραφέας comment_11925 Let me add, while the buzzing goes on, all lights are working and are strong. Αναφορά
Δημοσιεύτηκε Απρίλιος 17, 201313 χρόνια comment_11926 Which model do you own? I own the C5 with the EFI engine and after a long time of not using the bike I might have to use the lever switch in the left hand, it pours more fuel to start the engine, I think. Αναφορά
Δημοσιεύτηκε Απρίλιος 17, 201313 χρόνια comment_11927 tell us your model and i ll translate your problem to the society but, i want to ask you, 1.does the electric starter run or not? 2. if it runs; are you sure that your bike has fuel? Για ελληνική βοήθεια [url=http://www.royalenfieldclub.gr/forum/index.php?/topic/829-starter-problem-help-ελληνικό-κείμενο-για-βοήθεια-στον-camillako/]εδω[/url] Αναφορά
Δημοσιεύτηκε Απρίλιος 18, 201313 χρόνια Συγγραφέας comment_11947 Hi guys and thanks for this. The bike is a classic 500 EFI Rata: im not sure if the starter works, there is this buzzing noise non stop like i was saying. and when i try to turn her on it goes quiet, no more buzzing, but nothing happens at all, total silence. i pushed her to try to force start her and the engine burped a couple times but didnt ignite. fuel OK. Αναφορά
Δημοσιεύτηκε Απρίλιος 18, 201313 χρόνια comment_11956 where do you live? i m not sure but i think in voula,right? tomorrow i ll be in your area. so, i ll send you a pm with my phone number to call me one more question when you push the electric starter button,the lights continue to work strong or not? well, you ve recharged the battery but maybe it has not enough power to start the engine. Αναφορά
Δημοσιεύτηκε Απρίλιος 22, 201313 χρόνια comment_11995 Does the problem persist or its straightened out now ? sounds like the starter solenoid if everything else (battery , fuel , etc) checks out. Επεξεργάσθηκε Απρίλιος 22, 201313 χρόνια από το μέλος Γιώργος Αναφορά
Is something wrong?
thanks
